If your mixer outputs use TRS, you can use TRS cables and you will have a balanced signal. If your mixer outputs use TS, you may as well use TS cables because you will have an unbalanced signal regardless of cable. It probably won't be a problem unless you have a long cable run.robbyrobmusik said:OH SO when they say XLR/Phono/TRS connector that means you can connect any of the 3. And balanced means that it ruduces the noise. basically i am going to be connecting my monitors to the mixer. So whith this type i could just connect it via TRS right?
bennychico11 said:well, first off...don't plug a microphone into the speaker.
