Yo Abalagula- Check the impedence. Usually, when a dual channel power amp is bridged, it changes the impedence the amp is looking for. For instance, my Carver PM125 power amp is a 2 channel amp looking for 4 ohm monitors. When it is bridged, it becomes a one channel amp looking for an 8 ohm cabinet. My bass cab is 4 ohms, and my guitar cab is 8 ohms. Up to a point, it's OK to drive an 8 ohm cab with a 4 ohm output, although it is not usually very loud. Sending a signal that is looking for 8 or 16 ohms into a 4 ohm cab, as I understand it, is very bad. You will get your best sound, and possibly avoid blowing something up, by making sure that rated output and input impedence are matched.-Richie
