The question is what do YOU think of that mic. It's "YOUR" money.
* Large 1" (25mm) HF1 gold sputtered capsule
* On body control of polar pattern, HPF and PAD
* Three position variable polar pattern - Omni, Cardioid or Figure 8
* Three position variable High-Pass Filter - Flat, 40Hz or 80Hz
* Three position PAD - 0dB, -5dB or -10dB
* Ultra low noise, transformerless surface mount circuitry
* Wide dynamic range
* Internal capsule shock mounting
Power P48 (48V) phantom supply
Acoustic Principle Pressure, Pressure gradient
Directional Pattern Three position variable - Omni, Cardioid or Figure 8
Frequency range 20 Hz - 20 kHz
Output impedance 200Ω
Signal noise ratio 87 dB SPL (A - weighted per IEC651)
Equivalent noise 7 dB SPL (A - weighted per IEC651)
Maximum SPL 147dB SPL (@ 1kHz, 1% THD into 1KΩ load) (157dB with PAD at maximum)
Maximum output voltage +16dBu (@ 1kHz, 1% THD into 1KΩ load)
Sensitivity -36 dB re 1 Volt/Pascal (16 mV @ 94 dB SPL) +/- 2 dB @ 1kHz
Weight 860gm
Dimensions 209mmH x 55mmW x 55mmD
For me, the noise floor looks good, and therefor the S/N ratio. The Max SPL handling looks great. And variable patterns too. What's not to love...?
At that price what's the catch? NT2000 seems favored OVER the nt2a. But at that noise spec and SPL, do I really need a pair of AT4022's? Not flat like your SDC options. Perhaps harder to shield from the wind. So what is the intended usage? The specs seem to suggest anything anywhere IMO for the nt2a. Not a fan of Rode in general. But if these come in matched pairs, I could learn to love them as a stepping stone to more expensive options.
https://www.youtube.com/watch?v=CCzMwwBadJY
https://www.youtube.com/watch?v=KEZLQAnASzo
https://www.youtube.com/watch?v=POsR2RE62FM
https://www.youtube.com/watch?v=nJ_TzUVH6QQ
