H
Havoc
So, I have about everything to record in duplo, but nothing seems to work toghether. I guess that a different multi-track soft might do the trick. But it should have the following:
1: audio centred. This is most important. I like Sonar for its intuitive working, but hate having to think in measures:tick or frames. Time ruler shouyld be h:m:s:ms. Don't use any synth, sequencer whatever. Only need for midi would be to send a click track but consider that a seldom used option.
2: support real-time plug ins. Like CEP even more, but it fails here
3: have something like busses on a mixer so you can mix some tracks with FX, send it to a bus, apply fx to the bus and then mix the busses for the result without leaving the pc.
4: run on a dual amd pc. Tricky this one, but the money is gone so this machine will have to do it for the next year or so.
