Bottom right picture doesn’t look normal. Looks like the plug is offset.Thanks. Yeah I opened it up and everything looks good from what I see. Whatever came loose I can’t find it or hopefully it’s nothing worse. Will take to a tech this week.
Attached are some pics if that helpsView attachment 117699View attachment 117702View attachment 117708.
I’m not familiar with the guts of this machine, but in the bottom right hand corner that 4 wire plug going to the small board looks off.,
Yeah I think it was something like that. Already repaired! I can find out more. Unfortunately, I don’t have all the tools to deal with voltage so would’ve not been able to fix it on my own.Can the tech repair it? Needs some new capacitors maybe?
Hi, if you need a tech I can give you his name by message. He's near Los Angeles, to my knowledge he doesn't fix things by mail. Fortunately he had the parts, I brought some parts, and others could be fixed. The lack of signal ended up being the transistors and the p.s. reg. on the power supply. Also fuses f1 and f2 had to be replaced. There were other minor things he was able to repair to bring back to factory spec. The lesson in this was, always go to a good tech if you have one. I was nervous, but actually got it done at a really fair rate. Less than what it would've been if I would've bought replacement parts on ebay and tried to fix it myself. Also he was able to find little things that could cause an issue down the line and repair those.Glad to hear you're in good shape! I'm always looking for a good tech. Where are you, and who did you use?
Do they fix things that arrive by mail?![]()
