Disclaimer: I am not a complete idiot, despite what my actions might say about me.
So, I have had this Behringer KX1200 keyboard amp/PA thing for about 9 months, and it's worked pretty nicely. Until yesterday.
Yesterday I received this kind of rinky-dink Realistic stereo reverb system (radio shack reverb thing) in the mail (I got it off of ebay.) So, I plugged it into my amp using some RCA cables from the Main out section of the reverb unit into the tape-in part of the KX1200 - then I plug in an acoustic guitar with pickup into the 1/4" microphone jack of the reverb thing.
No problem, it works well (as well as a rinky-dink reverb thing could be expected to work) and I'm jamming away - so I decide I want to record it by plugging it into my mixer (Behringer Eurorack mx802) so I connect the amp to the mixer, with an unbalanced 1/4" jack, except - because I am too lazy to use the main out on the back(and because it was late and I didn't want to wake anyone up) - I decide to run the 1/4" jack from the headphone out of the amp, into the mixer.
Oops - now the amp doesn't work... like it's supposed to.
Now I turn on the power and the power light flicks on for 1/2 second, and the shuts off, and instead of working, a hum comes out of the amp - the hum is a "B" an octave and a half step below middle C is this helps the diagnosis. The headphone jack still works, because when I plug in headphones, the hum stops coming out of the speakers, and instead comes out of headphones. Oh yeah, the hum comes out even when master volume is turned all the way down.
When I plug an instrument into the amp - nothing happens, just the same old hum - no instrument sounds whatsoever. The hum does not respond to the master volume control, only in that it started "fluttering" when I turned the volume all the way up, but the volume didn't change.
Okay, here's the weird part - if I play something using that rinky dink reverb box plugged into the tape in of the amp - then I can hear stuff - instruments, etc. So, apparently they tape-in of the amp still functions??
So, any ideas about what the hell's going on? I'm asking you guys first because I am too embarassed to explain this, plus I'm sure that I have not kept the receipt for the amp, and I'm sure my stupidity has long ago voided the warranty anyway.
You think this thing can be fixed?
Thanks...
Thanks...
