rvdsm said:When it comes to mixing, the best and only advice I can give you is to listen.
Listen to albums produced by other people. Listen to your own work. Listen to work done by others with equipment similar to yours. Listen through different speaker systems. Listen through headphones. Listen, listen, listen.
It's no trick, all you have to do is listen and you will eventually be able to mix well.
