VS-880 with Cubase?
  • Thread starter Thread starter DJTonyMOMO
D
DJTonyMOMO
I was wondering If i could sync my vs880 with my cubase program? If so How do I do it? Thanks in advance
I've done it with the 1824 and the 2480. If the 880 has a midi output, connect it to the midi input of the computer. Set the 880 to put out MTC and make sure the frame rate is set the same as it is in Cubase (most of the time it is 30fps) Then you just have to set up Cubase to look at that input on the sync page. Turn the sync on in Cubase, and hit play on the 880.
You should also make sure that the timeline in Cubase matches the timeline in the 880.
