Sal Paradise
hey there,
i'm having a problem with my Vox AC30, i hope you can help me out. thanks a lot.
first up, since quite a while the amp makes weird relatively loud noises when i adjust the "brilliance" volume. not all of the time though. its annoying, but oh well, i lived with it. then two or three months ago in the middle of playing, the fuse died.
i researched a bit and read somewhere on the net that it can happen quite a lot with that amp, cause the amount of current can get too high when turning the amp on. hm. they recommened a stronger fuse, but i got the same one again that was in there. well, changed the fuse, finished the last few recordings, didnt do anything until now.
well, i moved and was generally busy, never having the time to really try it out, and now for the first in a while i just turned on the amp again. tried to come up with a halfway decent sound, as it was sounding kinda thin sounding. as always, between fumbling around with various adjustments i turned off the "standby" switch, to not get the loud sound again. still, no luck with the sound, until i decided to just turn up the volume a bit. so yeah, i switched on the amp, and the fuse died again.
well, do i really need to buy a stronger one like recommened on the page i found? change the valves?
thanks so much for your help in advance,
sp.
sp.
