D dirtythermos New member Aug 31, 2007 #1 My Ernie Ball volume pedal is sticking a little. Should I use WD-40 or graphite to lubricate the mechanism? Thanks!
G ggunn Crystal Flavolian Aug 31, 2007 #2 dirtythermos said: My Ernie Ball volume pedal is sticking a little. Should I use WD-40 or graphite to lubricate the mechanism? Thanks! Click to expand... I would use neither. WD-40 evaporates to leave a sticky residue and may leave you worse off than you were. Graphite is a dust that doesn't stay where you leave it and can get into pots. It's somewhat conductive. I'd use Teflon grease.
c7sus Disenfranchised Member Sep 1, 2007 #4 I had a landlord that swore up and down that oil from the sides of his nose was the best lube on his door locksets. Really.
