H
HomeMadeHitShow
Member
Hey there, I am a simple home recorder with a question. Please keep that in mind when answering
I have started having trouble with vocal volumes in my mixes. Typically if I get the levels right on one system, they are typically too loud or too quiet on another. For example a good monitor mix will sound too loud in headphones or two quiet in the car. I also find the vocal volumes too loud when the song is played at low volume.
The problem of course is that if I fix for one system then it messes up another.
I am thinking this may be more of an EQ or compression issue. Any thoughts on this for the home recordist would be greatly appreciated.
Thanks
Tony
Thanks
Tony
) do like i do -- listen to commercial mixes through the speakers you mix with, and compare those to your own.
