Here's what you do....
I am thinking that you obviously have a graphic equalizer onthe system right? If you don't, don't bother reading on, get on down to the music store, or look in the local classifieds and get one!
Set everything up like you normally do. Turn up the mic volumes till the just start to feedback. Turn it down just a hair.
Now, go to your graphic eq, and turn up induvidual bands one at a time till you find the one that is causing the mics to now feedback. Remember to turn back down any band that is not offending here to the setting it WAS at before.
Once you have found the band that is causing the feedback to occure, turn that band down from it's original position about 2 or 3 db.
Now, turn the mic up again until it feeds back.
Go through the above steps until a desired volume is achieved.
Now, that is how you can get more volume on the PA without feedback, but there is nothing in the world that says it is going to sound any good at all!!!
Some of the problems you may be experiencing is:
Crappy speakers.
Crappy cross overs between the bass speaker and horn.
Crappy Equalizer.
Crappy mic preamp on the mixer.
Crappy cable (yes! I once let a singer use a Monster
Studio Pro 1000 cable during a rehersal. We didn't change any setting at all, and got about 3 db more gain, and no feedback out of the PA. He was shocked...
Hard reflections in the room.
It is waaaaaaaaaaaaaay too loud.
With all but the last, you will just plain old need better equipment.
With the last, well, TURN THE DAMN BAND DOWN!!!
I have done live sound for many, many years now. I have mixed on little 12" and horn systems with about 200 watts of power to 4 way systems with over 100,000 watts of power. Little dinky rooms to 3,000 seat theaters to festivals. Teenage local bands doing their first gig to Grammy winning artists. I have mixed em all and in every situation imaginable.
You know what I have noticed? The less experienced the band, the louder they played. The less tight they were the louder they played. But all in all, all but the biggest time bands I have mixed, and a few locals with great musicianship play way to loud for the room they are in. Rooms have a sort of "saturation point" for sound. If you exceed it, you will never get a good sound without feedback. Small places suffer the most from this.
Also. I would take the damn
C-1000S out of the mix here. You just don't need a condensor mic for vocals, and that particular mic tends to be very high end heavy as it is, and will create all sort of problems when used on voice.
You wanna know the best vocal mic overall I ever have used for live sound? The one that time and time again delivers excellent output vs. feedback, excellent feedback rejection, very clear even sound?
You got it. The old standby SM-58. Not
the Beta 58. Not the wanna be 58 48. Not the wanna be Radio Shack 58. The good ol' SM-58. Anyday of the week I would take that mic over any other for live sound, UNLESS, I have worked extensively with the performer and they have excellent mic technique, and can really belt it out over the band, stuff like that, would I EVER consider another vocal mic for live. I used to mix for a band a lot and the singer had his own Audix OM-5. It worked very well on his Barritone voice, and we used it everywhere. But this was the exception rather then the rule for live vocal mics.
Get rid of the 57 and C-1000 and get a couple of 58's. I am not saying that virtual ray's endorsement of the Audix OM series is bad, but I have had way better luck with 58's with a majority of singers. Plus, if you take your 58's with you to a club that has sound and a soundman, they will more then likely already be using 58's, and will be prepared for yours as far as having the monitors "rang out".
Good luck.
Ed
