I used to have egg carton bed foam on the walls and truthfully.....it worked awesome for how cheap it was.
This reminds me of..."where angels fear to tread"...type statements.
Ok MAYHEM1, at the risk of invoking the angels laughter, well, here goes.
Subjective statements of how a room sounds are exactly that. Subjective statements. What you need to understand is the term TRANSLATION. The whole point of a control room is to evaluate the sonic TRUTH of your recordings, and there are a ton of variables that must be solved in order to PROVE your monitors/room is not lying to you. The proof of the pudding is how well your recordings TRANSLATE to a variety of other systems/rooms.
First off, your statement doesn't DEFINE which room you are referring to...ie...when you say it sounds AWESOME, does that mean the BOOTH sounds awesome when you are IN IT, or does it sound AWESOME in your monitoring space when you listen to the LIVE DIRECT sound from the mic's over your monitors, or does it mean when you listen to the PLAYBACK from your recording device over monitors, or does it mean it sounds awesome over headphones..either in the BOOTH or the monitoring space..or does it mean it sounds awesome when you play back your recoding in a car, or other room on a playback system..
See what I mean?
Furthermore, WHAT sounds awesome? The music? The bass? The vocals? The guitar? The RT-60?
Furthermore, do you mic the musicians in spaces other than the booth? If so, how do you evaluate the sound in those spaces?
There is more to defining what you are hearing than AWESOME. Awesome at what frequency? Before or after EQ? And where in the room? Is AWESOME yours or someone else' evaluation? And if it IS awesome...then what is the problem?
Ok, here is the deal as far as I'm concerned. Before you can effectively evaluate what you are hearing in the booth, you need to understand that recording engineers first line of defense is TRUST that what they hear in the control room, is for all intents and purposes. pretty much what you will hear on EVERY other system/room. This is called the PRINT. It is a sonic signature of what decisions the engineer has made, and are made by trusting the room in which he monitors is NOT lying to him. If it lies during tracking, then it lies AGAIN when mixing. You can NOT make good sonic decisions if you are not hearing the truth. SO....
So, I'm asking you to tell us more about your monitoring environment before I delve into your booth improvements. BTW, a SQUARE room is the 3rd worst possible recording environment. A cube is even worse, and your room height is very close to the L/W dimensions. The worst is if everything is concrete.
So please tell us more. It may turn out your MONITORING space is the area of improvement concern vs the booth.
Of course, my non-expert disclaimer is in full force here.
fitZ
