> I stand corrected. yes, you need to route the returns to the rec > buss outs. that's the bottom line.
You were standing OK. Maybe in need of a little adjustment to your casual alignment.
>So JJM. does this mean that he can't do this with his present set-up? If i read this correctly, he would need a pair of analog inputs to his DAW for the rec buss outs.
The REC outs are automatically routed to channels 1-8 in L/R pairs and then can be routed to the ADAT out to the DAW.
This is what I am doing, in general.
This provides the ability to process up to 6 analog channels in, channels 9-16 of ADAT input, and 2 effects, to the REC bus and then out two channels back to the DAW as stereo. And also to monitor this through the REC bus jacks.
>I am thinking of purchasing the Dakota card. although i probably will only utilize software FX, I'm curious as to your response.
The info I have read makes this a happy card. I would not have had to purchase the midi interface and the USB PCI card.
In the Spring I purchased a Yamaha dsp factory with the ax16 adat i/o card, discontinued, but a great combination.
I thought about the Tango-Wavecenter combo, but I do not record many instruments at once. And I wanted a mixer/control interface.
I purchased the VM200
to have the familiarity of an analog mixer
to be able to control Sonar and the dspf via midi
to be able to keep everything digital, once I got it in
The VM200 has 20bit conversion. So does the Yamaha DSPF. I think the Yamaha may have better converters, but it is only 2 channels in. (The effects and mixing are what I wanted from the Yamaha.)
I was concerned about not having 24 bit conversion until I read an article at Alesis.com
Go to
http://alesis.com/support/faqs/index.html Click on ADAT and then on "Welcome to 20-bit digital recording."
'Tother day my 5 year old granddaughter and I played with the echo and reverb effects using headphones. She visits a couple days a week. I take her to dance and music classes. When she was 3 and 1/2 she was still saying "W's" for "L's." And her mother was listening to some 60's and 70's greatest hits.
One of her favorite songs still is "Countwy Woads."
Countwy Woads take me home
to the pwace I bewong
West Virginia, Mountain mama
Take me home Countwy Woads
And, "I'm weaving on a jet pwane,...."
'Twas a bit easier to use just the mixer and not have to mess with the computer to have fun with echos and my Emily.
Have fun
J
