BluesMeister
Occasional Poster
And now for your listening pleasure, I present the tutorial:
Using VSampler3 with SoundFonts.
You will need to down-load and installed the latest version of VS3 from www.vsampler3.com
You will also need to install MIDI Yoke. You can Google for MIDI Yoke. It’s free and very easy to install if you follow the installation instructions.
Warning! During installation of VS3, do not associate LM4 drum files with Virtual Sampler! Those LM4s have a .TXT extension, and every text file you have on your HDD will be associated with VS3 rather than your favourite word processor.
When VS3 is installed it can be run as a standalone sampler or as a Dxi in a sequencer. The following instructions are specific to using VS3 and CakeWalk HomeStudio2002.
1) Start CakeWalk
2) Start a new project or open a current one.
3) Insert an Audio Track
4) Drag the bottom of the Audio Track pane until the FX box is visible.
Right Click on the FX box and choose VS3 Dxi
When VS3 is loading you see the Splash Screen for a few second. This will be replaced by the VS3 main view – however it is severely truncated. You must drag the bottom RH corner until you can see the main view as intended.
BluesMeister
1) Start CakeWalk
BluesMeister
Walk this way, please...
