Vegas Pro 9 - What's New?
shackrock
Anyone know what's new for audio in Vegas pro 9.0? I just got an email from sony abuot it, but I CANT find out what's actually new for audio in it...looks like a lot of HD video/Blu Ray stuff is all...
The Vegas Pro 9 collection integrates two powerful applications that work seamlessly together to provide an efficient and intuitive environment for video and broadcast professionals. This comprehensive suite offers the most robust and progressive platform available for content creation and production. With broad format support, superior effects processing, unparalleled audio support, and a full complement of editorial tools, the Vegas Pro 9 collection streamlines your workflow. From acquisition to delivery, from camera to Blu-ray Disc™, the Vegas Pro 9 collection delivers exactly what you need to produce outstanding results.
Precise Editing Tools
Edit SD or HD video with drag-and-drop functionality, mouse and keyboard trimming, and ripple editing. Features include ProType Titling technology, multicamera editing tools, 32-bit floating point video processing, customizable window layouts, color-coded snapping, improved HDV/SDI/XDCAM support, Cinescore plug-in support, A/V synchronization detection and repair, and auto-frame quantization. More about video editing
Efficient, Professional Workflow for 32- and 64-bit systems
The Vegas Pro 9 interface provides a fully customizable workspace for accomplishing a wide range of production requirements. Dock multiple windows across multiple monitors, and save your layouts to fit specific editing tasks; nest Vegas projects within the timeline, customize and save keyboard commands, and use application scripting to automate repetitive tasks. System-wide media management produces maximum efficiency. Network rendering saves time by using multiple computers and networked drive arrays to render complex projects. Vegas Pro software also supports 24p, HD and HDV editing. More about the Vegas Pro workflow
Broad Format Support
Vegas Pro 9 software natively supports the newest professional camcorder formats including XDCAM EX and RED. Vegas Pro 9 software also includes support for still images greater than one gigapixel in resolution. Use Pan and Scan to create a stunning movie sequence from these large pictures while maintain HD resolution. More about the Vegas Pro Capture and Import
Superior Audio Control
Use unlimited tracks, 24-bit/192 kHz audio, punch-in recording, 5.1 surround mixing, effects automation, and time compress/expand. Apply customizable, real time audio effects like EQ, Reverb, Delay, and more. Expand your audio processing and mixing options with supported third-party DirectX® and VST audio plug-ins. Use the Mixing Console for precise audio control. More about audio production
Powerful Blu-ray Disc Authoring
Burn movies to Blu-ray Disc™ directly from the Vegas Pro timeline for high-definition delivery. Use DVD Architect Pro software (included with the Vegas Pro collection) to author DVDs or Blu-ray Disc media with multiple video angles, subtitles, multiple languages, and special features. Preview and test your work in real time. Apply Brightness and Contrast, Auto Levels, Crop, and Anti-Flicker filters. Set CSS and Macrovision® copy-protection flags for masters. More about Blu-ray Disc authoring
Interactive Tutorials
Vegas Pro 9 software has a comprehensive help system, as well as detailed interactive tutorials that provide walk-through demonstrations of common features and functionality. These tutorials provide an easy step-by-step method of learning the product and the workflow necessary to complete most common tasks.
well yeah, I read that already on the site... but what's NEW from the v8? I can't see anything that wasn't there new from V8 to V9 in terms of audio... but I'm sure there are some updates not listed there.
http://www.sonycreativesoftware.com/vegaspro9/compare
nevermind - thats not what you want, that's just the other current vegas packages.
the only new features i saw were:
Darker color palette New! (hardly even a feature)
The Vegas Pro 9 user interface features a new color scheme, which provides an optically neutral environment for optimized viewing of colors and enhanced usability when working in a darkened editing booth.
and
Added Default Layouts New!
Vegas Pro 9 software gives you the option of several default layouts with windows arranged for various editing tasks. These layouts can be further modified and saved for a truly customized layout and workflow designed for the way you work. New in version 9 are the Audio Mixing and Color Correction layouts.
Try this link
https://homerecording.com/bbs/register.php?a=act&u=93257&i=bdb41dbfaa5ea5aa13794b5313b6c31f0b362c44
What's New:
Video Features
4K support for frame sizes up to 4096x4096
Support for capturing directly to XDCAM-compatible MXF files from supported SD/HD-SDI sources
Automatic source media adjustment for working with mismatched media
Enhanced 32-bit floating point video levels mode designed to work like 8-bit mode but with the precision needed for 10-bit and higher sources and render formats
Gradient wipe transition
Glint, Rays, Defocus, Starburst, Soft Contrast, and Fill Light video effects
Audio Features
Place and edit audio without quantizing to frame boundaries, while still quantizing video edits
Multichannel audio adds from Trimmer Window
Editing and Workflow Features
Includes native 32-bit and 64-bit versions of Vegas Pro software
Enhanced user interface with layout presets
Impressive lighting effects including Glint, Rays, and Fill Light
Darker color palette UI for optimized viewing
Audio Mixing and Color Correction default layouts
Browse XDCAM EX and AVCHD contents in Device Explorer
Import, Export, and Hardware Features
Import and edit XDCAM EX files natively, no conversion required
Support for gigapixel images
New! Read and save DPX, OpenEXR, and Microsoft HD Photo formats
Open and edit RED ONE™ files on the timeline
Device Explorer for AVCHD and XDCAM EX devices
Awesome thanks for the help guys, I was looking for this information so I'm glad I stumbled upon this thread.
Thanks again,
-Jill
