sile2001 said:
I'm trying to find a way to relocate my amp off-stage (like in another room) for my live stuff so I can really crank the amp without interferring with the house sound. The problem is that due to my positioning on stage, these runs could be 40ft long or more. Consider a 40ft run from guitar to amp, 40ft back from effects send to my pedal board, then 40ft back to the effects return, and that's gonna be a fair bit of signal loss.
Would I be able to solve this problem by using direct boxes on both ends so I would have a balanced low-impedance signal making the long runs?
Probably don't need to go that far, equipment-wise. From guitar to amp, there is a thing called a line driver, which will give you a low-impedance line signal, which won't suffer from cable capacitance. Kinda spendy, though. Pete Cornish makes one. Boss used to make a pedal called the Line Driver, you may be able to find one.
Many effects pedals, including
the Boss TU2 and GE7, have a low-impedance output, and might work as a front end. In any case, you will probably have to set your amp a bit differently.
If you do go the DI route, realize you will need an active DI for the guitar to amp run. A passive DI won't have enough input impedance, and your tone will probably suffer.
The FX loop will already be low-impedance, most likely, and shouldn't need DI boxes. The manual should tell you. In the FX loop, noise will probably be a bigger problem than loss if it is low-impedance, unless your FX loop is balanced. If not, some noise problems can be cured using DIs and a couple cable mods.
