Inserts... Do you mean plugins?bad news said:im recording 24/96....when i use inserts im recording at 32 bit float/96...what do u guys think is better...applying inserts..or recording and then cleanin up..is there any flaws or diff. in quality when using inserts..thanks
I agree, it's always better to record the signal as dry as possible. Some people will apply eq while tracking, some don't. I try to get the best sound going in, and if that means a little eq, I will give it. But I don't use anything else (plugins, hardware effects).mwarkentin said:The biggest problem with this is that there is no way to go back to the original sound once you've recorded with the plugin. It is probably best to record the signal as clean as possible so that you can mess with the plugins afterwards, incase there is something that you missed when recording.
