I want to use some analog inserts with the Mbox2. However, I can't seem to find clear instructions on doing so. Do I use the left and right analog outputs of the Mbox2 or the left and right analog inputs for the inserts ?
If it is the two outputs, then I can't monitor what I am doing, only by headphones. This does not seem correct. If it is the two inputs, then I can see that working fine.
So, I have been sending the stereo mix out from Ptulz and into my mixing board and using the channel inserts and aux sends their to my analog gear. However, when I try to record back into ProTools with the L/R ins, I am flirting with feedback disaster.
I have muted the channel to be recorded on, and send its output to an unused bus, but unless I have the mix dial all the way to the right (only monitoring playback), feedback is a problem.
It seems my sound quality is degraded somewhat with how I have this set up. Is there a better way to do all of this, and what am I missing ? Maybe I need a more comprehensive mixer ? I have the Yamaha MG10.
Thanks !!!
Thanks !!!
