Secret Clubhous
Some of you may remember responding to my thread "Device driver crashes in XP" roughly a month ago. Thanks to those who offered solutions/suggestions. Well, I finally got thru to Tascam & nailed down the problem. They told me "this device is incompatible with AMD VIA chipsets. We've always recommended not using that chipset," as if it were common knowledge. (Naturally, that is the chipset I have.)
Well, I don't know if anyone here has heard about that? A bunch of experienced folks here offered suggestions but nobody was aware/informed of the conflict. The local pro audio store I bought it from certainly didn't mention it. The salesman just said, "this is what you need. It will work with anything." Though I'd found it cheaper online, I bought locally because I wanted to support local businesses. Plus the store is highly regarded for their knowledge & service, but even they knew nothing about this issue.
Neither does this info appear anywhere in Tascam's promo, spec sheets, or in the mini-manual for the US-122. The mini-manual says it has been tested & is compatible with about 4 or so Intel chipsets, but says nothing about not using AMD VIA, or anything else, just that incompatibility would be "a rare case" with any system.
Tascam advised to do the tweaks at musicxp.com, which I did...& lo & behold, the Blue Screen of Death after 15 min. editing in Cakewalk HS04.
They also said to roll back to the old driver if the tweaks didn't help, so I did. Haven't fully tested that yet, but I have serious doubts it will make much difference. Tascam's last piece of advice was "get a new computer."
Right....this IS a new computer!
So it looks like I'm probably SOL & now have to buy a new soundcard & mixer. Needless to say, I'm pretty pissed about not being informed of the incompatibility before I bought the device. Which, BTW, is a great little box for the price & seemed perfect for my minimal setup using both MIDI & audio.
I'd recommend it for anyone w/similar needs, as long as it is compatible w/your system.
anyway, a few questions for those with ideas on the subject:
1. So what IS a compatible PCI-based soundcard/breakout box that does MIDI & audio & is compatible w/AMD VIA? I don't need lots of inputs, just something reliable that I don't have to mess with a lot to get it working.
2. Do I have any recourse worth pursuing in terms of getting a refund after 8 mos. tearing my hair out, crashing at least 4x a day?
3. Does anyone know of a website or thread that lists specific incompatibilities between software, hardware, etc? Or is this something the end user just has to find out the hard way? Maybe we could start a sticky thread on this subject?
I hope to get away from having to mouse everything.)
