Sifunkle
Hi all,
I'm something of a noob, so apologies in advance (and also if there was a more appropriate forum to post this in), but I'm trying to learn...
I've been using a Lexicon Omega audio interface to record all my stuff (vox, guitar, bass, drums) and mix in Cubase. For the most part when mixing, I've just stuck to using software effect plugins etc within Cubase (other than occasionally sticking a stompbox or two between the guitar and the Omega!).
However, I'm trying to expand my understanding of equipment a bit (get outside my comfort zone) and am wondering if it would be possible to somehow route vocals through say my distortion box or phase shifter? I'm thinking about this more as an academic exercise than anything else...
The Omega has 2 XLR mic inputs, 4 line ins (low impedance, balanced/unbalanced), 1 line in (high impedance, unbalanced), line out L&R, and some other connections I suspect aren't relevant in this case. I'd post a URL if I could, but you'll have to google it
Each of the mic inputs has a TRS insert point, which acts after the preamp: I'm pretty sure if I had the right cable (1 TRS to 2x TS) I could possibly use that to insert my MXR bass distortion into the pathway, prior to the AD converter. Is that correct?
Is there any other way I could achieve this? Perhaps record clean vocals through the mic input as usual, then run the track through the Line Out to the stompbox and back into one of the Line-Ins?
And finally, how would this sort of thing usually be rigged up, eg. in a live setting? (For instance, I'm believe the singer of At the Drive-In sometimes sang through a flanger.) Is this where a mixer would usually have use? (I'm none too familiar with the use of mixers, other than the minimal mixing function the Omega has...)
Any feedback appreciated. I'm really not a tech-head, but I'm trying to learn a bit (been reading through the guide at Tweakheadz Lab).
Cheers,
Si
(Oh, unrelated bonus questions: Without getting into the confusing electronic physics of it, what's the difference between balanced and unbalanced lines, ie, how do I know which Line-in I should use for various analog inputs?)
Cheers,
Si
