delirium trigge
I've never done this and I would like if anyone can instruct me. I have the FCB1010 which will change the banks and amp I'm using. But then I have the Pod hd500 which I use as a midi controller which will do both, but I kinda want to just use it for effects, which I know how to program it to do.
How would I go about using both at the same time. Do I go midi out from the FCB1010 into midi into the line 6 and midi out to the 1101, amplitube, or anything else I'm using? (1101 is my live rig with mesa 50/50 power amp through mesa cab, at home I do the same thing with amplitube) Or do I wire it the other way around?
I have tried to get the FCB 1010 to do more than just simply change the banks, but it won't do it. If I want to use the wah pedal on it, I'd have to turn the wah on via a patch that already has it on, or turn it on with the hd500.
I'm okay with having two midi controllers. Because I end up with too many patch's that are the same amp with different effects because they won't all fit on one.
