Thought I would use a second post for my feelings on tuning:
1> Put the head on slightly tight, then STRETCH THE HELL OUT OF IT!!! By this, I mean pushing on it with you fist, elbow, knee, head, face, whatever you use. (Just make sure it is blunt)
If it is a base drum, and you are not over-weight, STAND ON IT! (I mean the batter head only, the one your base pedal beats on)Stretch those things for a while. This helps keep the tuning IN TUNE.
2> When tighting lugs, do so in a criss-cross/opposite pattern. For example, if you tighten the lug at the 2'o clock position, then tighten the lug at the 8'o clock position next. 12'o clock, then 6'o clock. 3'o clock then 9'o clock. ect...This keeps the tension somewhat even.
3> When you get the drum close to where you want it, press your finger in the middle of the drum, then tap the head close to where the lug goes through the hoop. Be sure to keep equal pressure on the middle of the head with your finger for all the lugs. Go through and tune all the lugs as close as you can this way so that the pitch sounds similar.
Tune the bottom head slightly lower than the top head.
HERE IS A LITTLE TRICK!!!!
This is an AWESOME trick I have used ever since I learned it, and MANY, MANY pro drummers do this when tuning. (Well, maybe some of them have their drum-tech do it for them..)
Anyway, after tuning the top head, and getting a good sound out of it, DETUNE the BOTTOM lug of the drum. (By bottom, I mean in relative position to you facing the drum.)
Hit the drum while tuning the lug DOWN just a little at a time. If you do it right, you should here the tone of the drum EXPLODE!
You get this kinda low ummmmppphhh that was not there, and is not reproduced any other way. It also might take some RING out of the drum, if you have any. Trust me. If you do this the right way, you will LOVE it, and do it EVERY time you tune drums.
3> As far as heads go:
If you are recording, and give a shit about it, BUY ALL NEW HEADS!!!! TOPS AND BOTTOMS!
I know a lot of people think "But I don't hit the bottom heads with my stick, and they look alright to me!"
But that is not logical. There is A LOT of wind generated INSIDE the shell every time you hit the drum. This forces air against the bottom head, causing it to ressonate. Sure there are no stick marks, but the head IS being stretched. And after being stretched fo awhile, it is going to lose its tonality.
For most applications, SINGLE PLY heads are the way to go. Clear on the bottom, coated/non-coated on the top, which ever you prefer. Not that big a difference in tones.
My personal opinion is to NEVER RECORD with two ply heads. (Pinstripe, Fiberskin3, Emporers, etc..) If you have limiters/gates etc, then you need not worry about overring.
And besides, SOME OVERRING ADDS TO YOUR SOUND! Some people try to totally eliminate the "ring" associated with drums. THAT IS PART OF THE SOUND/TONE!!!!
Now, for playing out/touring, I would never use anything but two-ply heads. They last WAY longer, and the sound is FINE for live situations!!
Well, I hope I didn't ramble on too much, and that someone got some useful tips from my brain droppings!
Latre...
