Is using a tube mic alone nessisarily an better than running a solid state one through a tube preamp instead? I can see how maybe the tube section of a tube mic might be best optimized to work with the rest of its internal components, but assuming the quality of the outboard tube preamp is good enough, couldnt you pretty much achieve the same result with SS? Seems this would be more economical in the long run if you own several mics SS mics than ever buying a tube one just for that sound.
