Well, any post that answers all your questions would be a very large post. There's a lot to consider. I normally wouldn't go out on a limb to recommend computer recording to anyone not already familiar with computers because I won't be there to help them when they have problems. But, since you are posting this message, don't you already have a computer? Anyway, there are various cheaper and easier solutions. You could get an ADAT, although you won't be able to edit like on a computer. You could get one of those new
Boss BR8 recorders that record to 100MB Zip disks, if you don't mind the limitations. But it sounds like you have your mind set on a computer. An important question is: how much are you expecting to spend? A new computer itself might run you around $800-$900.
One good thing about computer recording is that you can use the computer for other things besides recording. So that is one thing to consider: what else do you want to do with it? Get a computer that can support everything you might want to do, including recording. Another thing to consider is whether or not you have any friends with computers. You may want to get the same type as them so you can share. By "type" I really mean Macintosh or PC. If you want a Mac you need to buy it from Apple. If you want a PC compatible, I recommend buying it from Dell. (www.dell.com) Yes, you can find cheaper computers. But Dell's prices are usually good, quality is very good, they select good components, they have good service, etc. My last two computers have been Dells.
The good news these days is that pretty much any new computer you get is going to have enough power to handle a lot of tracks. I use a 450 MHz computer and it is plenty. Today, new computers are usually at least 500 MHz or so. But if you want to use a lot of plug-in effects like reverb, more power is always better. I'd recommend making sure the CPU is Intel. Not that others won't work OK, but with Intel you'll be assured of compatibility. Plus, recording software uses floating point processing to do mixing and Intel tends to be better at floating point speed.
Another thing that may influence the type of computer you want is the recording software you want to use. For example, if you want to use Pro Tools, you'll need a Mac because Pro Tools only runs on a Mac. But as you said, you don't know what software you want yet. This is pretty much a matter of preference, though. But if there is some other factor that causes you to choose either Mac or PC, then you might get the computer first and figure out the software later. Many recording software companies have demo versions you can try out.
The sound card is usually something you can decide on later, after you get a computer. But of course, you need to consider the cost in your budget. You can get half-decent sound from even a $100 sound card. But to be more professional, you'll want to at least get something like the Event Gina for a little under $300. From what I hear, the GadgetLabs 8/24 is a really good at $500. (Another great thing about computer recording is that you can always upgrade pieces of it and add on.)
Anyway, that's a start, but it's by no means a complete answer. It would help if you provid more information about what you want to do and how much you expect to spend.
Jim
