GamezBond said:
also what are the differences between the Trinity and Triton, I remember seeing someone on hear said they used both of them
KORG TRINITY
Sound Generation Method:
ACCESS (Advanced Combined Control Synthesis System)
Sound Source:
ACCESS =32 voices, 32 oscillators (single mode); 16 voices, 32 oscillators(double mode)
Keyboard: 61 notes Sensitive to velocity and aftertouch
Effects:
Stereo digital multi-effect system - 2 master effects and 8 insert
effects simultaneously. 14 effects algorithms for master effect and
100 effects algorithms for insert effect.
Program/Combination:
56 programs/256 combinations for ACCESS, 64 programs for MOSS,
additional 256 programs/256 combinations for ACCESS plus 64
programs for MOSS are available when PBS-TRI optional board is installed.
Sequencer Section:
20 songs, 100 patterns, 1/192 resolutions, 80,000 notes, 16 tracks,
reads and writes Standard MIDI File
Controllers: Joystick, Ribbon controller, 2 x Assignable switches
Control Inputs: Damper pedal (SUSTAIN), Assignable (SWITCH, PEDAL)
Outputs:
DIGITAL - ADAT compatible (option), S/P DIF (option), ANALOG - 1/L/MONO, 2/R, 3, 4, Headphones
Inputs: DIGITAL - Word clock IN (option), S/P DIF (option), ANALOG - 1, 2 (option)Phones
Floppy Disk Drive: 3.5 inch 2DD/2HD
MIDI: IN, OUT, THRU
Display: TouchView Graphical User Interface, 320 x 240 dots
Power Supply: AC, Local voltage
Power Consumption: 22W
Accessories: AC cord, Preload data disks (TFD-00P and TFD-01P)
Dimensions: 42.92 (W) x 13.71 (D) x 4.96 (H)
Weight: 31.42 lbs.
KORG TRITON
Sound Generation Method: HI (Hyper Integrated) synthesis system
Tone generator: HI synthesis system; 48 kHz sampling frequency, 32 Mbyte PCM ROM, 425 multisamples + 413 drum samples. Sampling; 16 bit, 48
kHz stereo/mono sampling, 16 Mbytesmemory standard,
expandable to 64 Mbytes. Maximum of 1,000 multisamples / 4,000
samples. Up to 128 samples can be assigned to a multisample.
AIFF, WAVE, AKAI (S1000/S3000) and Trinity sample data can be
loaded. (Triton cannot load Trinity format data from TFD-1S, TFD-2S,
TFD-3S and TFD-4S , since they use data-compressed data.)
Sound Source: 62 voices, 62 oscillators (single mode)/ 31 voices, 31oscillators (double mode)
Keyboard: 61 notes. All keyboards have velocity and aftertouch sensitivity.
Effects:
Stereo digital multi-effect system - 2 master effects (mono in,
stereo out), 5 insert effects
(stereo in / out), and 1 master EQ (stereo in / out) simultaneously.
Number of effects: 102 (insert effects/ 89 for master effects)
Program / Combination:
640 programs, 512 combinations, 64 drum programs, GM Level 2 -
256 programs + 9 drum set
Sequencer Section:
16 timbres, 16 tracks, 1/192 resolutions, 100 preset / 100 user
pattern per a song, 200 songs, 20 cues, over 300,000 notes, reads
and writes Standard MIDI File (Format 0 and 1)
RPPR (Realtime Pattern Play / Recording): 1 set with 72 patterns available per song
Arpeggiator: 5 preset patterns and 232 patterns (approx. 180 preset)
Controllers:
Joystick, Ribbon controller, 2 x Assignable switches, 4 x Assignable
knobs, 3 x Arpeggiator control knobs
Control Inputs:
Damper pedal (Responds to half-pedaling), Assignable (SWITCH,
PEDAL), PC interface (TO HOST)
Outputs: Main = L/MONO,R, Individual = 1, 2, 3, 4, Headphones
Inputs: 1, 2, Level switch LINE / MIC, Level volume
MIDI: IN, OUT, THRU
x 240 dots
Accessories: AC cord, Preload program disk TNFD-00P, TNFD-01P
Dimension: 1074.4(W) x 348.5(D) x 122(H)
Weights: 14.2 kg
