Yes, it is. I've never heard it called that either, but a quick search throws up a NAB adapter, which is described as "Enabling the use of NAB spools on a machines with trident hub". So yes, it appears to be the normal cine-type spool which the R8 uses.I don't want NAB or AEG, but the other option is called trident. I've never heard of a trident hub. Is this the format that will fit on a Fostex R8?
http://www.rmgi.eu/pdf/RMGI_analog_studio.pdf
LPR35 is the replacement for Ampex / Quantegy 457 & there are pictures of all the types available in the .pdf link above.
7" trident looks like the right one for the Fostex R8?
Well, they're the same formulation so I'm not sure about the difference in headroom. Thinner tape would certainly be more susceptible to print-through, though.I used to use Ampex 456 with my Fostex A-8, there was a bit more headroom & less print through from what I remember compared to 457?
I was planning on using SM911 or SM486.
EDIT: LPR35 is definitely what I want. I neglected to notice how many feet of tape would be provided.
