mitosis
A thousand post and a thousand answers on tracking levels on this forum and yet I still can find no confirmation regarding my specific problem. I'm posting this in the Newbies forum becuase I don't want to bother the other areas. I hope someone can answer this question quickly becuase I have a guy laying down drum tracks tomorrow morning. Heres the deal:
My main question is are my levels too hot and are they going to cause me problems later? I'm tracking drums and just running 7 mics into two MG10/2s hooked together. My preamps are set correctly and the meter on the mixer shows that at full playing volume, the meter stays at around +1 to +3 and occasionally hits +5. The mix never peaks on the meter though.
I then run that into a firewire interface. The analog input on that is set to the highest possible level: "0". (I have a feeling this is part of the problem.)
I record using n-track and don't adjust the levels on there (it is set at +0.0).
My playback volume is pretty low (lower than normal music volume on my computer). I know that this is normal during tracking. But if I apply compression and limiting to the drum tracks I recorded it is still much quieter than comparable solo drum tracks.
I have a feeling that my levels are too hot to begin with and I just need some confirmation on that and some suggestions on what part of the chain to turn down the levels so I can get more volume. Or am I completely retarded and should quit now?
Thanks a lot.
Thanks a lot.
