The installer crashes before it can begin work but after it has gathered my options at the start. It gets as far as choosing a location to install to and then, just as it starts, Windows steps in with the message:
"flstudio_10.09c.exe has stopped working".
I am running it from a download, originally, from my external USB hard drive, on which I keep copies of all my programs and settings. I've used this installer several times already and it's been absolutely fine.
I didn't think to check the Event Viewer, but I've never actually got much info that I can personally digest from the results. Lots of jargon.
One thing which crossed my mind, since I was advised to purchase the 64bit version of
Windows 7, that it might not be compatible with this rig I built around an older, AMD Athlon processor. But in the properties panel, it does say:
AMD Athlon 64 Processor 4000+ 2.40 GHz. Then, under that, it says
64 bit Operating System. I am still a little confused about that side of things, to be honest.
It's disappointing, because the installation of Windows went so smoothly and I felt I was really getting somewhere for once. I've drawn up my plans for a custom rack-mountable case which I've designed and can't wait to build the machine up properly and start hunting for a silent PSU which will fit into my plan.
I believe that if I keep it running clean and efficiently, with just the basics, this could be a really solid little computer to run my DAW app. on and serve as a stand-alone system for editing the results from the MR-8 recorder unit. This FL Studio software has always run very smoothly on it, even with an array of free, 3rd party plugins I collected.
