you can.....but that would mean double-take a solo (recorded twice) and then panning it one left 30% and the other right 30%. Its hard to record and capture a solo dead on, in 2 takes.......which is why most people just record a single take for a guitar solo....
but you can do that. It will sound BIG..........but your guitar player will hate you for it, trying to record the guitar solo twice and playing it exactly the same way is very hard to do.......
in panning.....there is no right or wrong way to do things.......just a more creative approach on how you do it will separate your mixes with the rest.
I'll pan a track in the center all the time. I will usually have this track pretty quiet comparatively, and roll out a lot of lows and low mid stuff so it doesn't get in the way of the bass too much.
SORRY BUT THIS BOARD IS FUCKED UP AND WONT LET ME MAKE NEW THREADS SO I AM GOING TO HIGH JACK THIS THREAD I APOLOGIZE
what are your best techniques on getting a really CLEAN guitar sound, obviously the amp matters a ton and the tone and the guitar and the player, and what color thong im wearing
my buddy just picked up a deluxe reverb... its a tube amp for those who dont know. I want to supply him with the cleanest recording i can.
I want that beuatiful tube amp sound to come out on recording, how should i go about doing so.
some mics i own
dynamics:
57's
e609
SCDs:
Rode nt5
Oktava mc012
behringer ECM8000
LCDs:
AT4050
MXL shitties
and so on
If you want to cheat because your guitarist can't recreate a miracle twice do this:
Copy the track
Slide one over ~20-30ms
Pan each to taste
Also recommended: (eq them slightly differently)
It'll give more definition to the guitars and make them sound thicker (like 2 people are playing it), you'll also avoid "big mono", and your guitarist won't want to murder you in cold blood. I know, purposefully pulling a guitar out of time just seems like sacrilege, but trust me....it's a God-send sometimes... Just my .02
P.S. It's known as the "Haas effect". Look it up if you don't believe me!
y
I double almost every solo I play. It's not that it's hard, it's just most guitar players don't take the time to sit down and write a lead. They'll shoot from the hip and hope for the best.
Here is my advice with the guitars:
get a guitar splitter. Go into two or three amps. Have one be the meaty heavy gain, one be the midrangey overdrive guy, and then on glassy and clean.
Put these mic'd amps on three faders and you'll find there will be a magic balance where you get all the chunk and fizz from the heavy, all the punch and guts from the overdrive amp, and the clarity and tonality of the clean. I do this a lot with a Dual Rec, a JCM 800, and a Fender Twin.
example:
www.yellowmatterrecords.com/slate/AmbrosiaNewMix.wav
Well, two things. the whole idea behind doubletracking is that the second part is NOT absolutely exact. If you want absolutely exact, then you just copy the track or chorus it, but the results are entirely different from playing the part twice. And if you track it twice, vive la difference!ummmm.....its pretty hard. Its very difficult to capture every single nuance, and phase exactly played as the first take.
There's one important thing everyone is leaving out. Check your tracks in mono. There's all kinds of things you will discover when you do this worst of which can be your wall of guitars completely disappearing. I just finished a metal album with the best guitar tracks I've ever done. They were all eq'd/compressed in mono FIRST. Then panning. Then checked in mono again.
Second, if a guitar line is *that* nuanced, it probably is more of a lead than a wall of rhythm, and is probably not a great candidate for doubling to begin with.
G.
