thedude400
So this seems to happen to me very frequently in home recording. I take the very minimum and what's cheap or free and I try to make it work as long as absolutely possible, or until I'm on the brink of insanity. I have reached a crossroads yet again where I've come to the realization that it's either continue to try to squeeze out the last drops or buck up and fork out some money. Before it was my buddy's copy of Cool Edit Pro for a year or so until I decided to fork over $150 another friend of mine's copy of SX2 (he was switching to Logic). When I first learned how to use Cubase it was amazing and defintely worth the money. But when switching I realized my little Pentium 3 with 256mb RAM wasn't going to cut it. So I raised the bar to a P4 with 768mb RAM (not too much of a jump but enough to get me off the ground). So now after downloading free VST instruments and effects on the internet for over a year, I'm starting to realize the obvious notion that when it comes to free vst's, free does not mean "bug free" nor does it mean "minimal cpu" or "minimal ram" useage. Not to mention the products are rarely that impressive anyway. It's gotten so bad that I find myself either constantly mixing down files to 1 track, or I'm freezing almost every track except the few I'm currently fiddling with. Some free VST's max out my cpu usage meter when 2 keys are being pushed simultaneously. I would like to be able to run between 15-20 tracks at once with at least a compressor and a verb on each. Plus I'll be using Native Instruments Guitar Rig 2. The point is I want to step up and not only buy a synth/instrument program (most likely Native Instruments as well unless influenced otherwise), but I would also like to build the most suiting computer I can for around $500. And that's what I would like help with.
I have all the help I need as far as building the computer small accessories (usb ports, extra video card, tower, mouse etc.). My Dad has been building them for years, but seeing as he isn't into audio recording like myself he wouldn't be able to direct me towards the right components to buy to fit my needs. I would love to be able to mix down with all the tracks running and tweak accordingly, a luxury I have never been able to pull off.
Where should I put my money? I've done a few searches and found a little bit of information but nothing specific to my situation. I've read that a dual core processor would be good. Also at least 1 G RAM if not more like 2 seeing as VST's supposedly drain mostly RAM. And I think I also read that a bigger hard drive does more than just give extra space, but can also improve the whole recording process too?
