Ya know what I'd like? I'm gonna tell ya what I'd like . . . A 1974 Ford Pinto Squire Wagon 2.3L 4-cyl 4sp M/T.
This cracked me up. Back in the early 80s I had a buddy who inherited one of these and stuck a 4v 302 with a top loader 4speed and an 8.8 mustang rear in it. We use to build monsters. My GTO is set up for torque cuz I always build motors to last and that means keeping the rpm under control. I'm pushing ~490 ft lbs. Clutch ripping, diff distroying, tire shredding, suspension twisting torque.
I have to beg to differ on the carb opinions however. Rochester quads have vacuum secondaries meaning you cant "open" all four barrels, the secondaries have to be properly set up to open at a rate that works best for the stall speed of the converter , the GVW etc. and they are pretty useless for manual gearbox cars.I have had to repair plenty of these that had been 'modded" to make the secondaries open manually -normally, the modder's 'mod' wouldn't allow the secondaries to open fully or at the correct time anyway, causing all kinds of reliability/drivability issuss. I can get a Rochester two barrel to perform as well or better than a Q-jet off the line/0-60 MPH and I can make just about any carb of any kind sit up and beg. But my secret weapon has always been knowing how to properly match and tune a carb to a specific application.
Holley carbs come in so many different styles that claiming that they had drivability issues seems a bit disingenuous . The standard 4150 style carb was designed for WOT operation which made it perfect for man trans cars but it was not optimal for auto trans cars and IME the drivability complaints I heard were all related to slapping a 750 4150 series on an auto trans car.
I tuned many of these for local dudes who insisted on using these "wrong" carbs, but for the smart kids I would talk into putting a 4160 style instead , they were very drivable and when I had set them up, would perform just as well or better than asbuilt Q-jet. Any carb needs to be optimized for trans type, cam, intake and diff ratio, tire size, GVW and if you learn each carb mfg's design choices, any one can be set up to be both high performance and reliable, though there will always be a 'best suited' carb for a particular combo. Say a Dominator style for Pro Stock or circle track.
Also a Q-jet is a spread bore style, and that design is inherently less effective in certain flow ranges, especially in stock style and open plenum manifolds. They do best IMO on dual plane design manifolds. It is a GM carb and was only ever offered on their vehicles. Holley was a provider to Ford, Carter sold carbs to both Mopar and GM and are super reliable when set up correctly. But it's always about the combination.
