aaroncomp
1-20-2009
This question may not have a clear answer, but thought I'd seek opinions. Currently I use Adobe Audition 1.5, and while doing a typical mix, I use a ton of effects. Over time, the number of tracks, and subsequently the number of effects has increased further. Needless to say, my creativity has started to become limited by this. So, one thing I realize I should be looking at is the effects I use and that I should perhaps be using them more wisely and less liberally. And, there's always the search for the more efficient, yet high quality plugin. Another thing that may change this is that I will soon be using Audition 2.0 which employs a much better routing and bus scheme allowing the consolidation of effects.
Okay, so what's my question? If I still seek more processing power, what would you recommend? My current setup is a P4 3.0E (HT 800FSB), 1GB OCZ (2-3-2-5), (2)10k Raptors in RAID0 on my OS/program drive, (3)7200 Storage Drives. It's basically, spend little now and get some boost or wait a bit, spend more and get more boost. Small things I've considered are adding another gig of RAM or rechipping my CPU with, say, a 3.4 - which of these do you think would have the greatest boost factor? Okay, after that I've got the option of a complete overhaul with new mobo, ram and cpu. Finally, there's the helper chips - DPS cards, second computer for effects, etc.
Thanks for any insight.
