TravisinFlorida said:50-13 seems pretty crumby. where's the audio samples? also "first 1000 $0.99 each after that $5.00 each". i think we could roll our own for $5.
He will not know until they get the new batch and do some testing. But it will be better.TravisinFlorida said:was a specific frequency response for the new batch mentioned?
Shipping will only be $3 to $4 in USSMX_Dizzy said:If you call sales do you still have to pay for shipping? Is it even still worthi t for $5?
Is there a thread or a website somewhere that shows how to do this? I'm really interested in buying (or making, now) low-cost small mics for my toms.mshilarious said:You can build your own MSH-1A for about $5 in parts and select whatever capsule you want to use.
SMX_Dizzy said:Is there a thread or a website somewhere that shows how to do this? I'm really interested in buying (or making, now) low-cost small mics for my toms.
Sorry if a simple answer is "search" but I'm not exactly sure what to search for.
mhelin said:MSH, which capsule you use on MSH-1C? Did you find a better one than Karma uses?
same here, back in the day that's how I used to record by micing up my Crate 15 watt amp with a cheap computer mic and I have to say it sounds good after all these years (about 3-4 years ago, when I started playing)TravisinFlorida said:exactly. hell i've used a $2 pc mic to mic a guitar amp and was fairly happy with the results. bottom line, you won't know until you try. at $1 a mic, where's the risk?
Geoff_T said:I've been using the 99c mic with a talkback amplifier (c/w opto compressor) I've made and it sounds bloomin' amazing... as I knew it would because I've cobbled these things together myself in the past. Using his XLR based version saves me a lot of bother!
Well in that context it should be called Phantom Voltage.... not Phantom Power.cello_pudding said:why does it say 48v phantom power?
that would use my entire amount....
They might not work as good as you want, but who knows? they might be pretty good.PhilGood said:Anyone seen a graph on these? Just curious as the high end only goes to 13khz. I figured "what the hell" and bought 6. Gonna try them on toms.
