And be carefull when you bend over - unless you like that sort of thing.Do yourself a favor, get off the internet and go to the gym and hang out with some men. And watch out for the guys who bring a towel to wipe down the equipment before they'll touch it.
windowman, insulting people on a message board does not nescessarily make you a man. Neither does going to the gymn.
Anyway, one of the benefits of 24 bit is that any processing you do on the signal starts with a higher resolution sound. This should lead to better sounding effects. It would be a good test to put the 16 bit file through a a sequence of effects, and compare it to the 24 bit put through the same sequence. While the straight up sound difference between a 16bit and 24bit source may be very subtle, the difference in a processed signal should be more obvious.
Another good test would be to mix a 16 track song starting with both 16 and 24bit source files - comparing the difference. I have often wondered if the benefits of higher bit depth in the source file are lost when mixing several files together. I guess if you can prove that each track sounds better after the processing of its track specific inserts, then it's going to sound better going into the mix.
I also agree that putting the files in MP3 format completely invalidates the tests. The difference in sound quality between wav and mp3 is uncontested, and is likely to mask a more subtle difference in sound quality.
For instance, if you add a hiss at -60db, it won't make a difference if the original signal has a 90db or 148db dynamic range.
As annoying as it may be, better to post wav files.
