Compression is not as easy to describe, but you can try a ratio of
2:1, or 3:1 (see for me to write that, you still may not know what he hell I'm talking about)
but anyway, the absolute BEST way to get this right is by ear.
pass your KICK, SNARE whatever into your compressor, (or add plug-in)whichever you use, and turn the knob to liking.
Now Chords is another entire thing, you are right in saying "most chords are the same and most are sustained to fill up a track"
but it's another art to learn --- "case in point" listen to any
BABYFACE track from 90---98 he uses the same exact chords, just switched around and the arrangement is placed around it.
Honestly I cant tell you what chord progression R.Kelly does, I dont listen to him that much, besides I got my own flow.
But they vary between minor & major chords, depending on what joint you listen too.
You gotta find yours, it is good to follow Robert, but eventually you will have to flip to find your groove.
Taming the hi-hats (dont laugh) it's as simple as sliding the fader DOWN
(everything doesnt always have to be up in a track).
B let me tell, the best way to get any track right, is to record it right in the BEGINNING, get the RIGHT KICK, RIGHT SNARE, the RIGHT HIHAT -- if it sounds good before all of the compression etc..., then maybe it doesnt need it as much ---- dont get caught in the hype that you need to add effects on everything simply cause you have it, in it's natural state, if the track is banging, then it's banging --- add a tad of reverb for fill, but then everything reverts right back to MIXING & ENGINEERING. Playing it is simple, but in the MIX is where it comes to life.
Hit me back with any other question
