P-J
Rank Amateur
Hi all.
I bought myself a cheap USB MIDI device the other day. It's just USB box with two cables (MIDI IN/OUT).
All seemed to be going well and I was recording some beats using Battery, however I've turned everything on today and MIDI from pads -> PC doesn't seem to be working. I can output from the PC -> pads fine, but not the other way.
Is there something I might be overlooking? I have the correct device and channel set up, but no MIDI program seems to want to record the device.
I'm guessing this USB box is shagged already, but any advice much appreciated
//edit : I have tested the MIDI ports on the drum machine by looping the MIDI out to the MIDI in and it loops back with no problems (??)
