You may have a cracked / loose solder joint.
If you are handy with a solder gun,..it can be an easy fix.
Though,..I cannot tell you if this IS definitely the problem.
Try opening the unit up, and inspect the solder joints around the power supply porthole...with a magnifying glass.
This is just one suggestion.
