thecolorofdave
Hi,
Okay so I am working on setting up a new recording rig at home. The basic set up is as follows:
TASCAM 688 machine, 8 channels > Using RCA to 1/4 snake plugged into the Group outs > 1/4 end is connected to a Zoom R24 interface, 1 channel per tascam = 1 channel per Zoom > The zoom runs in to PC through USB.
The problem:
I am using the Group outs on the tascam machine and running them into each of the Zoom tracks (8 inputs).
Im loaded on Scene 11 on the 688, my tracks are armed and volume up.
However it seems the group outs want to split everything into LEFT/RIGHT. So Ive panned each track on the tascam machine to either be HARD LEFT or HARD RIGHT..
But this poses a problem, if all my master faders are turned up, and I am tracking drums through the tascam - ie 4 microphones. The way group outs is sending the audio to my Zoom, is that 2 mics are panned left and 2 mics are panned right. And each track isnt an "individual" track. I am getting 2 tracks per one track (im unsure how to describe this...)
I want: I would much rather it be... I plug mic into channel 1 of tascam. RCA for group out in channel 1 is going to channel 1 of zoom. I get channel 1 of tascam on computer. I plug mic 2 into channel 3 of tascam... RCA for group out in channel 3.. going to channel 3 in zoom. I get channel 3 of tascam on computer. (Isolated from channel 1)
Im looking through the manual trying to find solutions for this problem, wondering if any of you may have a solution. Is there any way I can directly send each tracks output to my Zoom (if I center pan everything.. then ALL tracks are on individual tracks , which is a disaster for mixing because I cant target individual mics, they become a group)
Sorry for the wordiness of this post.
##Quick Edit:
Just so you know, this set up I am not actually tracking to tape, I am using the TASCAM 688 as a mixing console for its pres and EQ before sending the tracks into my DAW. My plan is to mix on my DAW, then send a stero track back out the pc into the TASCAM, and Record this mix to tape, do tweaks and then send the Tape MIX back to PC, to get a tape warmth to the final mix
The problem:
##Quick Edit:
