I am trying to get more of a technical understanding of tape and its properties. I thought I'd post some questions to our resident Tape Professors here as most of the information I am looking for is pretty much scattered around the net and not easily decipherable, at least not by me.
I read everywhere about different tape stock and bias compatibility and this or that tape switch setting for consumer grade machines and such.
However, I haven't really found anything on bias compatiblity and how to determine (technically) if two different tapes are bias compatible or eq compatible.
For example, I've read that Scotch 206 is bias compatible with RMGI SM911 (Ampex/Quantegy 456) except that 206 is +3 and SM911 is +6 (more questions on that later).
In addition to the 206 and SM911, I own some older BASF LGS 35 and LP 35. I think I've read that LPR35 is the same as SM911 but the only difference is the tape thickness. But what about LGS 35 and LP 35?
I have two charts, one for BASF tapes and one for Scotch that lists tape properties for each tape stock over the years. The charts show production dates, base material, thickness, backing, and the goodies such as Coercivity, Retentivity, and Remanent values.
Example:
1. BASF LGS 35 Coercivity is listed at 310, Rententivity Gauss 900, Remanent 900.
2. BASF LPR 35 Coercivity is 320, Rententivity Gauss 1650, Remanent 1800.
3. Scotch 206 Coercivity is 320, Rententivity Gauss 1050, Remanent (flux lines) 0.93.
Questions:
How do these values listed in the charts relate to each other and how can I tell if certain tapes are bias compatible or eq compatible with other tapes?
So what exactly does "bias compatible" mean? What about EQ Compatible?
Example:
Questions:
