Sustain signal not working in Cubase, works in standalone...
  • Thread starter Thread starter rocketdude
R
rocketdude
Having a problem with my sustain pedal. I'm using AKAI MPK261, Preset is set to Cubase, and I have loaded a XML-file in Cubase so I can remote control my DAW. Sustain pedal is connected to one of the footswitch ports, and it's function is set to "sustain" in the "Edit mode". Sustain works as it should in all standalone programs. But in Cubase, sustain is not working, nor recorded. Signal is recieved, and if I go into "Edit mode" on the MPK261, and change pedal function to play/stop, then I can use the pedal to start and stop the track in Cubase. So, the sustain function is not working, but if I change the pedal's function, it works for those given tasks.
Sustain worked perfectly in Cubase, up to recently.
I have to admit that I have a "strained" relationship to midi, there's always something that stops you from creating music. Might give this forum a try before I eventually sell most of my gear, and focus on acoustic guitar playing.
I'm using Cubase Elements 8, Win7.
Thankyou for any help!
