I have Insomnia and bored to death so....
i figured I would upload some more pictures of my progress
I opted not to make it a string through so I got another bridge.
Here I am laying out the holes for the neck fasteners which will go down1/4" from the top of the plate to the top of the neck pocket and splitting the difference on both sides.
here is a refrence pic of the hole lay out
once I have drilled the holes and transferred the hole layout to the neck and all the holes are drilled and the neck is secured to the body I make two reference lines of the outside of the neck on the body where the bridge will be placed.
I then measure down 35 1/16" on both sides of the nut from the outside of the neck and draw a straight line this will be the bridge fasteners center line.
then I find the center of the the neck at the first and 20th fret and make a line then I find the center of the bridge and mark a line on the center of the bridge, place the bridge on the body and align the fastener screw holes on the bridgecenter of the center line I made earlier for the bridge screws.
you can use a hand drill to drill the fastener holes. just try to drill them as strait as possible and you will want to mark the drill with a piece of tape to use as a depth gauge. you will need to measure the length of the screw then mark that length on the drill use this guage method for drilling the holes in the head stock for the string tree screw and the machine head fasteners
Sometimes there is some slop between the shaft bushing and the shaft so you can make a shim our of paper by doubling it over a couple of times until you get a good snug fit then you can proceed to lay out the holes for the tuning machine fasteners.
place the tuner in the hole with thepaper shim then use a small tri square or a small ruler with a square end then square the top of the tuning heads base and mark the holes with a sharpie.
once you have all the holes layed out drill all at the proper depth then install the tuning heads.
well, now that I have it done this far I can take it all back apart.
everything is in line and where it is supposed to be but I did not have an e string to check the saddle and nut but It has a nice low buzz free action
I am still waiting on pickups and the pick guard. by this time next friday it should be ppainted with a clear coat. Until then I have lots of prep work to do to the body before I can paint it.
LOL even at this point it plays better than that POS SX I bought last week
