Vista just plain sucks.. It's slow and expensive. It takes a long time to boot. It's a resource PIG, esp. that silly side bar, and the Aero ui.. It's cute, nice to look at, sucks to use. You need a GIG of ram just to boot it?? My P4 xp DAW runs circles around my laptop that came with vista, even tho the laptop has a T9500 Duo and 2x the ram in it! WTF?! I formatted the hd and stuck xp on it instead, now it smokes.
The new security is overkill, it prompts you so often it becomes habit to just click 'Ok' without even looking at it, which kinda defeats the purpose.. There's a LOT of hardware incompatabilities, esp. with old hardware, but even with new hw. Lots of hardware has no vista drivers. Graphics performance is terrible, WAY worse than xp.
I had IE crash so hard you can't even get the task manager up! Firefox seems to work better and faster. That's my short 1st hand experience with it.
Im in the industry, I know a ton of software developers, network engineers, etc. I hear complain they cant get common MS apps running on it to save their lives. wzup wit dat? They aren't morons! Oh ya, they want you to buy all those apps AGAIN, the Vista version! Everyone I know bitches about it.
Then there's cosmetic stuff like the start menu - what bullshit! It's impossible to find what you're looking for. Why should I have to re-learn the entire UI from square one? It's like if your grocery store randomly moved all their stock to diff. aisles..
Pisses me off.. No right-click / run with.. Laptop power options dont take into consideration whether it's plugged in or not. Why the hell not??? XP did! Total step backwards..
Then there's the implications of forcing hw manufacturers to jump thru hoops to obtain a 'Vista certified hardware' certification. In the interest of stopping media piracy, hw manufacturers can no longer use common efficient design methods like using common PCB's in all video cards, because hackers could tap into unpopulated bond pads and traces on the circuit boards and bypass the DRM! Everything has to be custom-designed and laid out so that there are no unnecessary accessible signal links on the board. This means that a low-cost card isn't just a high-cost card with components omitted. This makes the hardware cost MORE! "This increases motherboard design costs, increases lead times, and reduces OEM configuration flexibility. This cost is passed on to purchasers of multimedia PCs and may delay availability of high-performance platforms" — ATI. Non-certified video cards get their outputs disabled, YPbPr always, and sometimes composite tv-out. Same for audio cards, S/PDIF outputs are disabled.
Gates and Ballsack KNOW Vista sucks, they wanted to discontinue xp, but got so much backlash they had to extend the XP life cycle until 2010!
In short,
