The prior reply (#42) got held for moderation. If this one appears first, the thread could be somewhat confusing.
The drummer wants to upgrade the mains to the
K12.2 on pole mounts for better projection over the audience, and spare his back from hauling those extremely heavy Mackie 3-way mains around, but I advised him to either choose the
KW122 from the same product line as the subwoofer, or contact QSC to verify that the K12.2 will integrate well with the KW181. The DSP is probably tuned for delay and we hope that QSC has been consistent across product lines but just in case...
It seems that the K.2 line has an improved tweeter for better dispersion characteristics up to a higher frequency, so it may be preferable overall as long as it plays nice with the KW181.
Once the mains and subs match, I should be able to ignore time alignment, but I still need to figure out that 3dB bump at crossover with aux fed sub and a crossover fudged in Master Fader with the DL1608.
If he does buy matching mains, we could use the internal crossovers in the speakers instead of fudging one in the mixer. The QSC powered speakers have the mains crossovers built into the mains instead of the subs, so that is an improvement over the Mackie subs/mains where the whole crossover is in the subwoofer and incompatible with aux fed sub.
The QSC crossover is set to 120Hz apparently, so that means either the guitars are going to need to use the aux fed sub, or the low E string is going to lose a quarter of its bandwidth.
I checked the
EASE data on the K12.2 and the
EASE data on the KW122, but for some reason the treble looks fishy bad (way too much attenuation above 5KHz).
I am unfamiliar with EASE data/viewer so maybe I am just misinterpreting,
but it looks to me as if the QSC frequency response data is weird. There is an 'input voltage' curve and it is not even close to flat.
So if I am supposed to ignore the input voltage curve and take the frequency response data at face value, the K12.2 and the KW122 seem to have terrible treble response,
but the bass of the KW122 is down only 10dB at 20Hz and that also seems like improbably good, strong output that low.
Did they take the measurement with DEEP bass boost enabled?
Even worse, the K.2 and KW lines seem to have different methodology where the 'transfer function' is concerned, since they look radically different and confusing:
I have no idea what I am looking at.
The sensitivity plots are also confusing:
I emailed QSC and they were unhelpful with figuring out why I am having difficulty understanding the frequency response data they published. What you see is what you get.
The K12.2 claims 1dB more peak output, but has a smaller compression driver on the tweeter (1.4 vs 1.75) and uses slightly less input current at 1/8 power, but otherwise appears equivalent to the KW122.
However, the KW series claims that the power is split equally between the woofer and tweeter at 500W each and that also seems improbable even though it has a somewhat larger compression driver on the tweeter. The K.2 line indicates that the 'peak' power is divided up between woofer and tweeter at 1800W and 225W respectively and that seems more reasonable.
Any thoughts? I suspect that this spec on the KW series is just plain wrong. I never heard of a 500W tweeter in any universe. Maybe that applies to the KW153 where the tweeter and midrange share the same amp, but it cannot be right for the 2-way speaker, unless they are also throttling the amp back to avoid frying the tweeter crisp like bacon.
I think this improbable power allocation is just a mistake in the documentation, and I think the frequency response plots are also wrong, but I would really like to know so I can advise the drummer properly.
I asked the drummer to also consider the KW152 or KW153 as potentially a better mate for the KW181, but I suspect that is too heavy/expensive and the KW152 only has 60 degree horizontal dispersion...
I could use some advice here. It is not like I am going to be able to figure this out with a listening test. On a good day I have trouble discerning quiet speech from across a conference room table. I have brick-wall loss at 10KHz.
It would be a shame for my friend to buy speakers that sound as bad as my hearing is. However, I have already mixed for a band that uses the K122 without a sub and the speaker sounds fabulous to my damaged hearing.
What do you think?
Sorry for the long update. I could probably have dribbled it out a little at a time in back-and-forth banter, but this was easier for me to compose it all in one sitting.
Thank you all for your helpful input. This has been a fascinating plunge into the night life. I look forward to your excellent suggestions!
