Studio One Audio I/O setup
  • Thread starter Thread starter revnice1
R
revnice1
Prettys Girls in yo
I have all the INs and OUTs of my MOTU Traveler visible in the S1 Audio I/O Setup dialog - but when I want to select one from the dropdown in the track, there's only Input L and Input R.
How do I make them all available?
Thanks - rev
go to audio setup, and change the locations of the inputs the way you want it one good time,
should stay until you have to re-route again.
I found the solution:
Just to the right of where it tells you the Input is a little circle. That means even if you've correctly setup all Ins and Outs, you will only see a subset in the drop-down in the track.
However, if you click it, it changes to two overlapping circles and then the full setup is visible and selectable in the track drop-down.
