I recently bought a Stellar RM-5. I have not had a chance to really try it out, can't say if I like it yet. Also, it is my first ribbon mic, so I don't have another to which I can compare it. After reading posts here about the Nady ribbons and the Cascade Fat Head, and their ribbons, I emailed Stellar and asked about their claimed ribbon thickness of 2.5 microns. This is the response I recieved:
"At this time I do not have the means to accurately measure dimensions that small.
Peter "
These are the specs that they have for their mic on their E-bay store:
SPECIFICATIONS
Ribbon type & dimensions: pure aluminum 2.5 microns thick, 1.4 inches (35 mm) x .2 inches (5 mm) (LXW)
Polar pattern: Figure 8
Sensitivity: -54dB+-2dB(0dB+1v/Pa)
Frequency response: 30~15 KHz (+-3dB)
Impedance: <=600 Ohms
Recommended load impedance: 3000 Ohms
Max.SPL(1% THD@1000Hz): 148dB
Anyway, just a heads up that they apparently are not confindent that their specs are accurate. I am thinking they may have the 6 micron ribbon that the Nady has. At least the ribbon does not make noise when I turn the mic back and forth, so it isn't too slack.
http://cgi.ebay.com/Stellar-RM-5-Ri...7905051QQihZ003QQcategoryZ41466QQcmdZViewItem
Peter "
SPECIFICATIONS
