I was wondering if this unit can be used as akaraoke with reverb and compression without hooking up to a computer? Will I need use the headphone outputs or some to send the reverb to a pair of speakers? Or willthe outputs in the back will do it.
You will have to setup the interface first using the MR Editor, and use the main outputs in the back.
Once you have save the setting in the Editor you will be able to use it as a standalone device.
