My Alto preamp has begun to produce static, regardless of which of the two channels is being used. The inputs are Neutrik XLR/TRS, the combined XLR and 1/4" jack. The outputs are separate 1/4" and XLR jacks per channel. It began slightly a couple of weeks ago, and now it has become full-blown static and hissing, not predominant, but enough that it can be heard.
Here's the interesting part - if a 1/4" plug is in the input, then that channel no longer gives static, while the other one will be noisy until a 1/4" is put in (no cute jokes, now). Using an XLR will not stop the noise.
Has anyone else experienced this with these combo jacks? I'm tempted to replace them, just because it seems like the least costly solution, assuming that there is something wrong with these. I'll call Alto's service department (yeah, it's out of warranty), but I figured I would try the brain trust here first. If it matters, the unit is an Alpha Mictube preamp.
