Smithers XKR
The SR16 is a bit crap..
I am starting to regret buying it
The samples are very good
It has a lot of good kick and snare sounds
The toms are good
The cymbals are poor
I hate the horrible gated reverbs, so dated... I will run it dry and try to use to link up with the Midiverb 4.
I did think about trying to swap for a higher resolution DM5 module or a DM pro module but with both of those you need a trigger interface... and I have read that there are a load of technical issues and poor customer support with the DM pro module.
I like the sounds of the SR16 without reverb but the pads are useless, like an on/off switch with dynamic control and pressure, no workability or feel.
I used the keys on the Korg X5 for drum programming back in the day. The drum sounds on the Korg are very good but limited, but using keys gives much more dynamic expression due to the greater travel of the keys rather than the stupid pads on the SR16.
So can I link the SR16 brain to be triggered by keys on the X5 as a controller for the drum sounds without the need for an interface ?
The toms are good
