Re: Re: Re: SP B-3 Sound quality? is Allen in the house?
Ah, you are in Portland then. I've been jonesing to go boarding up at Hood with me mates all winter.
So, loose capsule, eh? Well, I'm glad that everything was taken care of promptly. Which dealer did you deal with? And yes, I'm sure the shockmount is available through them - whoever they may be...
As for the headphone thing: Yes, that makes a huge difference. When the mic is in figure of 8, the signals from the front and rear diaphragms are 180 degrees out of phase. If you speak into the mic and listen through headphones, this becomes very apparent for the following reason:
The sound coming from your vocal cords is traveling up through your head (Heed! Pants!) and impinging on the backside of your eardrum, while at the same time, the sound coming in through the headphones is impinging on the front side of your eardrum. When the signals are in phase, they combine and everything sounds normal. Dare I say...good. BUT! When the two signals - one travelling through your skull and the other through the headphones are out of phase- they cancel each other out because they occur on both sides of your eardrum at the same time with opposite polarity.
And that, my friends is THE textbook example of:
If you think there's a problem with a Studio Projects mic, the problem may just be all in your head.
Seriously, I hope you enjoy the mic and I'm sorry you had to go through having to do an exchange.
Let me know if there is anything else I can do.
Sincerely,
Brent Casey
Studio Projects Microphones & Stuff
Torrance, Ca.
877-563-6335
Sky Pilot said:
Hi Brent,
Thanx for the reply. I actually called the dealer here
in Portland, and they took care of it. Sure enough
it had a loose capsule diaphram. They said they never
have problems with the SP line, and it's a first.
They hooked me up with a new one, and although it
sounds better than the defective B-3, I still am confused.
Omni is great, Cardioid is great, fig 8 is better, but the rear
in fig 8 still doesn't match the sound of the front diaphram.
Is that normal? (It does indeed sound better than the first one though)
As for your question of am I listening through headphones?
Yes I was. Does that make a huge difference?
I don't have the shock mount yet. Is it avalable through the local
dealer or direct from you?
Thanks for your help & nice mics. I think the B-3, with it's
very usable sound and patterns may be one of the best
deals out there right now.
Thanks,
Sky Pilot
